Dont forget, you can connect a 10 ga. wire to each of two seperate switches and connect the two wires together in a pair for double the capacity.
Would this work?
I think the converter you shared above would work. I ordered this one which is supposed to arrive Friday. It is $100 but only 10 amps which will make it run at full capacity. (I also want to keep the alternator output amps around 40 or less) I want to try it just to see how it performs at full capacity and if it gets hot. If I am not satisfied, I will return it and get the KNACRO one in your link or possibly the 20 amp version.
Pictured below is the cable I put together last night to use. The 50 amp anderson connection will hook into a 50 amp anderson cable that I have connected directly to my vehicle battery. The other two leads terminating with the XT90 connector will connect to the XT90 to Aviation cable end. I also have an XT90 extension cable if needed.
This set up is portable and not really usable for charging on the road, but I am mainly testing the proof of concept. I have a total length of cable from the battery to converter at about 3.5 feet with what I think is #2 cable (just had it around). The XT90 cable is 10 ga cable that will carry the 48 volts.
Thanks, Scott.
I’m going to buy the 15A one and give it a try. I’m going to put the two 40A upfitter switches I have in parallel (they each have 10 gauge wire) and solder them to a dryer cord wire to connect to the 15A converter input. Then 10 gauge output from the converter should be ok to mate with the XT90 connector on the aviation cable. I’ve got a clamp-on ammeter, so I’ll check the current in each of the 10 gauge wires in parallel and the 10 gauge wire going to the aviation cable.
If the AC200P draws 12 amps from the converter, then the input current to the converter should be right at 40 amps. The parallel 10 gauge input wires should each carry about half of that.
Did I miss anything?
My transit has the 250amp heavy duty alternator, and the total current available from the 4 upfitter switches is 120 amps. The current use from the total of all 4 switches should be less than 50 amps, so I should be OK I think
@jkennon …I received my converter today and have been playing with it for about an hour. I ordered the 10 amp, but they shipped me the 15 amp which is a good thing. I think the 10 amp would have simply gone into auto overload and shut down.
I am getting a 573 watt charge rate and even though my input cables are fairly large, (I am using an 8’ extension as well on th input) the wire is generating some warmth but not bad. With my Isuzu trooper idling, the alternator would not output sufficient amps to keep the battery voltage from slowly dropping. If I ran the engine at 2,000 rpm I had plenty of amps to maintain this charging rate with the input voltage running around 14.4 volts. Just turning on the headlights and AC dropped the voltage to 12.43 while charging.
The 15 amp 12 volt to 48 volt converter is running considerably warmer than the 24 volt version I ran previously. If I were seriously going to rely on this for fast charging on the road, I would probably get the 20 amp model in the hope that while it is running, the % of operating capacity is lower which should generate less heat. The voltage converter put out a steady 47.95 volts even down as low as 11.5 volts input.
I would say the biggest challenge with the install would be having sufficient wire capacity to feed the input side and I’m sure you have a much stronger alternator in your rig than my Trooper.
Here is what I ordered even though it states 10 amp capacity, they shipped a 15 amp.
Update been charging about 90 minutes. Converter is hot enough on the bottom that I cannon keep a finger on it for more than one second. Started at 37% and now at 88%. Unit is running fine other than getting hot and the cables are all fine with no real temp elevation probs.
Thanks, Scott. My converter should be delivered tomorrow. I’ll let you know my results. How did you mount the converter? I’m glad the guy I bought the transit from ordered the heavy duty alternator (250 amp) and dual AGM batteries. The factory wiring from the two 40 amp upfitter switches didn’t look big, I’d guess 10 gauge, and I will be putting the two of them in parallel. Think that will be good enough? So, would the current draw from the AC200P be the same whether the converter output rating is 15 amp or 20 amp? If so, I’ll seriously consider getting the 20 amp one depending on my results. Know of anybody else trying this?
Scott-Benson Moderator
April 24
Amazon.com: LIVISN New Heavy Duty Voltage Converter Regulator DC/DC DC 12V…
Size:10A 480W Product Name: Car Truck Voltage Converter Regulator DC 12V to DC 48V 10A 480W Features: 1. 100% full power and stable current output, non-isolated module. 2. Waterproof level IP68 and anti-shock…
$99.99
Update been charging about 90 minutes. Converter is hot enough on the bottom that I cannot keep a finger on it for more than one second. Started at 37% and now at 88%. Unit is running fine other than getting hot and the cables are all fine with no real temp elevevation probs.
Your current draw will be the same no matter the amp rating. They will all be drawing around a little more than 50 amps. The only benefit ai could see by going to the 20 amp unit would be decreased operating temp. I have not mounted the converter but if I did, I would use some nylon tube spacers to hold the converter off the surface if the mounting surface could not get hot. This would improve air flow. A small 12 volt fan would prob work for long term charging too. As it is, I recharged from 37 to 100 percent at 573 watts with no issues other than very warm converter. I will now drain the AC 200 and recharge it connected to a pair of 70 amp hour agm batteries without any alternator charging to see how many watts I can input to the AC200 before the low voltage shuts down the converter
I have not seen anyone else trying this. I guess we are either pioneers or fools. Time will tell. Most of what ai have seen is connecting an AC inverter to the vehicle to power the charging brick for a 385 watt charge rate. The converter system seems much easier and eliminates having to use the charging brick. I think it may also work well to charge the AC200 from the vehicle batteries through the converter and then just recharge the vehicle batteries while driving which should be quicker
Installed the 15 amp 12v-48V converter. Two 40amp upfitter switches wired in parallel. With engine at idle, no charging, van voltage is 14v. Converter output is 48v. Flipped switches on. Charging AC200P at 573 watts. Input voltage to converter dropped to 12v. Output still 48v. Went from 83% to 93 % in 5 minutes.All at engine idle. Aviation cable got slightly warm. Nothing else. Will run down to about 30% and then charge back up to see if anything gets warm/hot
Looks great. I like the airflow around the converter. My setup would drop the voltage to 11 without engine being on. As long as your input wires are not getting too warm you should be good to go. If charging while driving, your voltage will most likely increase which should help the converter to run cooler. I got the most heat when my voltage was lowest.
I think this set up is much more desirable than running an AC inverter to get 400 watts of charge via the brick. You can always add an inverter and dual charge with the AC brick at the same time if desired
Great job!
Forgot to mention. Checked current with a clamp on ammeter. 26.5 amps from one of the 40 amp upfitter switches and 25.5 amps from the other into the 12-48 converter. 12.11 amps output from the converter to the AC200P.
Went for a 50 mile 2 hour drive today. AC200P started at 23% and ended up at 76%. Some stop & go and some on the highway. The aviation cable and the 10 gauge output from the converter got only slightly warm. The bundle of 10 gauge wires from the upfitter switches to the converter got warm. Need to check where they are buried under the seat on the way from the switches back to the converter. The converter got very warm. I could put my hand on it for a few seconds before I had to take it away. We’re heading out for a several week trip in June, so I may get another converter as a spare. Maybe the 20 amp version.
If you ugraded the 10 ga. input to 8 ga and went with the 20 amp converter that may help. My 24 to 48 volt converter that I had tried earlier got hot, but I could still touch it all the way around. The higher you can keep the voltage at the converter input the cooler it will run. If I were you, I would order the 20 amp converter, connect it up and do the same trial to see if you get cooler temps since it will not be operating at such a high percentage of capacity. Then…you could return the 15 amp if the 20 amp performed better or return the 20 amp if there was no difference. I also thought about buying a small squre box fan (computer fan. Lots available on Amazon) that operated on 12 volts and mount it to blow lengthwise along the converter body. It could be simply wired directly to the converter input and would come on any time the converter was switched on.
Replacing the two 10 gauge switch outputs and grounds (4 wires) from behind the front dash back under the floor mat, under the front seat, and back to where the converter is mounted would be a not insignificant task. I can mount a 12VDC muffin fan underneath the converter rather easily. I think I’ll go that route first.
I found a couple of 20A 12-48 converters on Amazon. One is the same manufacture as the one I have, just at 20A instead of 15A. The other is Daygreen. It’s about $60 cheaper, but in the comments, they say to not use it as a battery charger. Not sure why. What do you think? Would it be OK to use it to charge the AC200P?
Daygreen
https://www.amazon.com/gp/product/B07KQSSWSR/ref=ox_sc_act_title_2?smid=AQUOPUUWMO7B7&psc=1
Knacro
https://www.amazon.com/gp/product/B07BMRXZ2W/ref=ox_sc_act_title_3?smid=A1OB26G8TSLEZQ&psc=1
I think they are both the same unit. Most likely the comment about battery charging is due the voltage would not shut off as would a battery charger and would just continue charging. Since the charge is controlled by the sogen, I would think this would not be an issue.
I’ve ordered the 20A converter and 15ft of 8 gauge 4 conductor cable to replace the 10 gauge. And I ordered a couple of small 12VDC muffin fans that will fit nicely below the converter. I’ll let you know how it all works.
A couple of questions:
What is the wire size in the aviation cable?
What is the efficiency of the AC200P inverter?
Jim K
16ga wire in the aviation cable. Around 90% inverter efficiency on my AC200. If you find the 20 amp converter works with significant less heat, I will probably swap over to that model as well.
Bought a small 110VAC 700 watt microwave with 1050 watt input for the van. Ran it through the AC200P inverter and the wattage used was 1250 watts. That’s efficiency in the low 80’s.
I would not assume that the displayed wattage on a sogen screen is accurate but more of approx. wattage
