@BLUETTI_CARE i performed the update this morning. The green light still stays on, blinking slowly with nothing plugged into it. It also still defaults to charging unless I toggle it off after shutting my van off.
Hi @mjday07, Could you please let us know the exact voltage of your car battery? We would like to further confirm this issue.
If the voltage is very low and the unit still cannot shut down, unfortunately, there might not be a better solution at the moment, and you may need to manually turn off the circuit breaker.
Hi @bluetti_harleyrydergmailcom, Could you please tell us the exact voltage of your car battery? We would like to confirm this issue further.
Hi @darrenduds20, Could you please let us know the exact voltage of your car battery? We would like to further confirm this issue.
@BLUETTI_CARE the voltage varies. But right now its sat at 12.3v. If there isnt a fix unfortunately i will have to organise a return
Hi @darrenduds20, I am sorry for the inconvenience.
Ill email uk customer service. I just can’t understand why you would design a unit that flattens the cars battery and doesn’t automaticallyturn off, every other dc to dc charger ive ever had will auto shutoff. Is it set to ever shut off ? @BLUETTI_CARE
@BLUETTI_CARE when the car is off it’s around 12.3. On it’s around 13.4 with the charger “off” even though it’s still showing 0.4v. What did the firmware you pushed even do because nothing changed on my end?
Hi @darrenduds20, currently, we don’t have any better solutions. We can’t set it as ever shut off, so manual operation is the only option at this time.
I appreciate your kind understanding and patience.
Hi @mjday07, Even when the power is disconnected, electrolytic capacitors may still have a small residual current due to the presence of the electrolyte, preventing the voltage from dropping to zero. This is why the voltage still shows 0.4V.
The firmware we pushed optimized the issue of repeated charging after shutdown. However, it seems that this hasn’t significantly helped your Charger 1. We don’t have any better solutions. We can’t set it as ever shut off, so manual operation is the only option at this time.
I have the same issue. Updated all firmware and the only way to prevent draining down the vehicle battery especially when parked a long period is flipping off the breaker.
Definitely not what was expected/promised. You need to stop shipping this product until this works properly because it’s a major part of functionality promised but not delivered.
This seems to still be an issue. I thought maybe a firmware update would fix this but I have had the C1 installed for a few days and noticed its still drawing a significant amount of volts/amps from my chassis battery.
How long after turning off the engine does it take for the C1 to only draw minimal from the chassis battery.
I need to try the firmware update intended to fix the Charger 1 “always on” indicator light without manual switching via the breaker. Charger 1 SN 12445000626565
Why in the world would a device be designed this way? Your pricy products seemed to be designed well. That this defect is not identifed in the misleading product documentation after customers complained at least months ago is quite disappointing. In fact, it seems less than honest and disrespectful.
Assuming that the firmware will not provide a fix, I respectfully ask that Bluetti company leadership provide a real solution and be responsible by immediately correcting your false advertising about automatic shutoff that misleads potential buyers.
Thank you for your assistance.
Hi @glencaves, For this matter, we’ve already pushed the latest ARM firmware in bulk, so customers can directly upgrade to the newest version.
When we initially designed this product, it was mainly intended to be compatible with traditional vehicles. Compatibility with hybrid and smart vehicles cannot be fully guaranteed, and some preset features may not function as expected.
This is not considered a product defect. However, we understand your concerns regarding potentially misleading advertising, and we will forward your feedback to our sales manager. Thank you for your attention and suggestions.
Hi I have this same issue - mine doesn’t stop charging when the vehicle is off.
To confirm I have a 2013 Landrover Defender - it does NOT have a smart alternator, and is diesel fuel, no hybrid etc.
I have updated to latest software and ARM, yet it still shows it charging after the vehicle is off.
When the vehicle is running the input voltage is 14.V+, when its off it drops to about 13.1 to 12.8. Surely its easy enough for it to recognize the vehicle is off?
This is in the main bullet points on your own website:
** Smart Protection: Automatic turn on/off functions prevent your vehicle battery from draining.*
Please update on how this will be resolved? I also tried turning the adaptive mode off, and this had no effect to resolve it.
Has there been any update to this? Can anyone confirm. I’m on the latest firmware and my charger 1 is still active, drawing power for bluetooth etc. while the car is off.
Wondering if with those that this happens, if the car battery is an AGM - voltages are different with these.
no, the charger 1 is connected to my main battery, just a standard battery. Its a 2011 Toyota Prado. Car Battery is @ 12.3 volts when off.
@BLUETTI_CARE Did you guys push the update for everyone? Whats your guys return policy. I would never have spent this amount if i had to use the circuit breaker to turn it off. How dumb is it to open your trunk each time you want to shut it off? If this was the case having to do this I would have purchased anker and used a solar panel is my back windshield. Please fix this asap. How can we return our items since your website lied and said there was an auto shut off?
