Ok, so the Charger 1 has to be turned off by the supplied circuit breaker. Which is the complete opposite of the what the product description and FAQ states?
Circuit breakers are for surge protection and were never intended to be used as an on off switch for a device. In that regard, why wasn’t an on off switch built into the Charger 1 during development?
Please clarify, as no where in the manual does is indicate that you have to use the circuit breaker as an on off switch. And that it doesnt actually auto turn off after 30 minutes as clearly advertised?
After 12 hours the green indicator light with no power bank connected is still flashing a solid green once every 2.5 seconds approximately. And no where in the manual does it say this either. Indicating it is still drawing power from the battery.
Hi @Overlander, We truly value your feedback and understand how you feel.
It was never our intention to mislead customers. If our user manual has caused any confusion, we will certainly relay your concerns to our R&D department to see if an update to the manual is necessary.
If you do not plan to use the circuit breaker, could you please try enabling the Adaptive Mode and test if that helps?
I have the same issue. Green light on Charger1 stays blinking endlessly. After checking on it after 2 hrs. I turn the breaker off. Green blinker shuts off. I did this test several times beyond 30 minutes. Each time the breaker has to be shut off. The manual should state this clearly. Flaw in design. I know eventually i will need a new breaker due to off/on back and forth. Will there be a OTA fix on this issue?
I have a ac180. How do i change modes on the app from Standard, Silent, Turbo, Adaptive mode? any other modes? and what is the difference between each mode? I went to settings on my ac180, NOTHING shows. It was at 56v, my ac189 at 70% full and charged to 100% less than 10 min. 30% of 1152 is 345.60- to charge to 100% less than 10 mins is really fast. Love it! Not sure if thats normal or good for life of battery.
I have also installed the charger 1 and have exactly the same issues as the above, its not turning off, even after 24 hours. Any update on a fix for this? Surely it should automatically shut down like it states in the manual. Im debating returning my elite v2 and charger 1
Any update? This is gonna quite an inconvenience if I have to turn the charger on and off everytime I use it to save from draining my battery. I will be returning mine if it’s not an automatic shutoff
@BLUETTI_CARE Hi I just installed the charger 1 and notice the device light stays on and continues to draw power from the battery while the car is off. Is there going to be a firmware update to fix this? This is not how the product was described in advertising and is going to damage the car. The breaker is not an on/off switch and shouldn’t be used as such.
Hi @mjday07, Yes, we have new firmware available to resolve this issue.
Please provide your Charger 1’s SN number, we’ll immediately push the firmware update.
Hi @darrenduds20 and @vakos, we have new firmware available to resolve this issue.
Please provide your Charger 1’s SN code, we’ll immediately push the firmware update.
Hi @darrenduds20, We have requested to push the latest ARM firmware for you.
Our IT department will push the firmware to your unit in 1 working day.
@BLUETTI_CARE Yesterday I installed my Bluetti Charger 1 in my campervan and am experiencing the same thing. This morning the green light was still on. Can I please have the NEW firmware fix pushed out to my Charger 1 unit? S/N = CHARGER 12502002560596 Thank You Very Much!
@BLUETTI_CARE I don’t see a SN but the PN is17.0301.1401-02A2. The number within the app associated with the charger is: 12501002372326. Hopefully one of these is correct.
Hi @vakos, Thank you for getting back to us so quickly.
Hi @bluetti_harleyrydergmailcom, Yes, it is our pleasure to help you.
Hi @mjday07, Your Charger 1’s SN number is CHARGER 12501002372326.
@BLUETTI_CARE i did the update. The light still stays on. It still defaults to charging unless I toggle it off and it still shows 0.4V output after the car has been off for a while
@BLUETTI_CARE i performed the update this morning. The green light still stays on, blinking slowly with nothing plugged into it. It also still defaults to charging unless I toggle it off after shutting my van off.
