My Bluetti AC180 P turn off, completely, when input AC from Grid is off, charge at 100%.
Eco mode disabled .
So bluetti AC180P has NO UPS FUNCTION ? .
Bluetti has latest firmware
ARM v2089.02
DSP v2088.02
BMS v1039.01
Yes, I have DC enabled in one case: Router , 12 W . It was off suddenly completely.
Another case was 3d Printer running at 60 W at normal printing stage. In that case, when light go off, it shut off completely. As the printer is directly connected to the outlet of AC180P, there should be no delay and it should continue supply.
Most of the time DC is on , for the backup purpose of Wifi Router. When 100% charged and then for a certain, random period of time, it went off completely
There is no error code mention. As it is shut off with blank screen. When turn back on , it is just like normal running condition.
Case 1: At the time of full charge again, at a random period of time, it shut off completely, having 8 W discharge.
Case 2: At the time of full charge again, when input from grid is off, let say i turn off the outlet, it drop and off completely
@minaunghein Did you see the error code on the APP? You can follow the below steps:
long press AC+DC at the same time until the frequency flashes, then long press the DC, and then you can see the error code. The left side is the code that reported the last error, and the right side is the code that is currently reporting the error. You can take a photo of this page and I can check.
@minaunghein Sorry for my late reply. E092 means BMS short circuit protection. Our engineers are unable to reproduce the problem you mentioned. We recommend that you contact the seller directly for repair.
Hello To same problem I bought ac180P it as a backup for my starlink. It turns off when charged to 100 percent. And when there is a power failure, it always turns off.As a UPS, this device of mine is completely unusable
I have the same problem until the device is not charged to 100%, the UPS mode works correctly. But if it shows 100%, then when disconnected from the power grid, everything will shut down with a probability of 100%. That’s why this device is absolute garbage from the UPS point of view. If you accidentally allowed it to charge to 100%, even with a slight voltage drop, it will shut down. This is very similar to a software bug. Because many people have experienced the same issue, and as long as it is not charged to 100%, everything works fine. Please fix the software.
