That’s some excellent news! I’ll wait for the mass release since I’m dealing with serious outages here, and I cannot afford instabilities due to beta software (not saying there are any, but I’m not taking the risk).
Kudos to the R&D department and all decision-makers at Bluetti. Took them long enough, but at least they care ![]()
@BLUETTI_CARE I want to echo @snmya as I’m also very glad to see progress on this topic and now that we know that the firmware is complete and just the app functionality is left to complete, I will wait for the final release and the official mass release version.
I may however return to request the firmware if the application update and mass release takes too long.
Thank you for continuing to work on completing this outstanding issue, this is one of the many reasons to purchase @BLUETTI products, for your customer care and attention.
Hi @snmya, @VSM, and @Teece, thank you all for your shared attention to this issue. Together, we have successfully achieved this new feature, which is a victory for all of us. I am truly delighted about this.
We completely understand your concerns; waiting for the new firmware release in batch and ensuring compatibility with the app is certainly the better choice. We have also followed up with the app team and will provide updates here as soon as we receive news.
We greatly look forward to your feedback after the upgrade—it is extremely valuable to us.
Спасибо
Я тоже жду версию прошивки
Рад что ваша команда этим занимается ![]()
Just to chime in, that’s very exciting news! I can keep the AC200 afterall instead of having to return it due to the missing feature, huzzah! Along with the others, unless it ends up being a very long beta period and the release does not seem to be coming, I’ll stick with the current software for the moment. Not really familiar with how trying the Beta might affect my other units or the warranty on it.
Very exciting news, thank you @BLUETTI_CARE for keeping us in the loop!
[quote=“4montIntra, post:118, topic:34821”]
Dear @BLUETTI_CARE,
I tested the beta version and it works great for me. Although only the AC initially was turned on before a full discharge of the battery, not only the AC output but also the DC outputs turn active after the battery is charged again to at least 5%, which is perfectly ok for me. Your work on this topic gives all of us trust that we made the right decision to buy Bluetti products also in the future. Thank you very much once again!
Hi @4montIntra, Thank you for your feedback — your input means a lot to us. We’ve shared it with our R&D team, and they’re truly delighted as well.
Your encouragement keeps us moving forward.
Wishing you all the best!
Hi @Pletenets and @fenorie, Thank you for your attention to our products and firmware—this drives us to develop new features.
We are also very pleased to start from users’ experience and meet your usage needs.
Once we complete the final testing, we will push the new firmware in batches and update it in this post. Stay tuned!
Может Ваша команда сразу сможет в прошивке посмотреть,о проблеме постоянной работы вентилятора на станции AC200PL,о которой я неоднократно Вам писал.
Дело ведь не в станции,как Вы ответили мне,а в прошивке,у меня у знакомых такая самая станции и такая самая проблема постоянной работы вентилятора в режиме тихой зарядки.
И в режиме custom ups,в режиме разряда и когда просто подключена сеть,но энергия идёт от батареи
Я конечно уже отчаялся,что мне помогут с этим
Но всё же надеюсь на Вас
@4montIntra @BLUETTI_CARE Hello!
This sounds not good actually. It should only turn back on what was ON at shutdown.
Different appliances could be connected and turned off by button/app earlier (instead of putting out the cables, which is bad for the socket lifetime). I absolutely do not want to turn on what was turned off intentionally!
I hope it will be changed or will be possible to change in the app.
Now it seems to work as “Turn on DC+AC after power on (and 5% charge)”
Should be “Restore DC/AC after power on (and 5% charge)”
Hi @Pletenets, We’ve actually explained this issue several times. The fan operation is not manually controlled — it automatically turns on or off based on internal temperature sensors and self-check mechanisms.
We have also reconfirmed with our technical team, and they believe this is not a malfunction, so there are no plans to develop new firmware for it. The fan’s operation helps with proper heat dissipation; manually turning it off offers no benefit and could even cause the battery to overheat.
We understand the noise from the fan may be bothersome, so we recommend placing the unit away from your bedroom to avoid disturbing your sleep.
Hi @snmya, The design of our new feature is to restore the original output settings, rather than enabling all outputs.
We are re-testing and reproducing the new firmware. If any issues are found, we will fix them immediately. Additionally, we will also develop a compatible app through which you can turn this feature on or off.
Please be patient while waiting for our officially released version.
А в чем несправность?
Я не могу понять?
Вот к примеру включается станция на зарядку в режиме стандарт 1200Вт,вентилятор работает периодически.
Как только я в приложении включаю режим тихий,800Вт, вентилятор работает постоянно.
Но по логике ведь должно быть наоборот.
И тоже самое при работе в режиме ups,сеть отключена ,вентилятор стоит,подключаю сеть, начинает работать! нагрузка не меняется,заряд не идёт.
Выключаю сеть,вентилятор выключается.
Я просто электрик,не могу понять в чем логика.
Но ведь четко видно зависимость работы вентилятора от алгоритмов ,прописанных в прошивке.
Ведь дело не в температуре,сама станция холодная.
Я ведь не прошу регулировать работу вентилятора в ручную,но он должен включаться от уровня температуры,а не от того, что станция включена в сеть или нет
@Pletenets @BLUETTI_CARE I think, there is a lot of confusion, including the one cause by translation, and topics mixing.
Fan is working when it should not, that’s overall impression. But please, create separate topic and re-describe again all states you see where you think it is wrongfully blows. From my perspective it is blowing too much indeed, when nothing happens, but I cannot describe it perfectly as I’m rarely in a room with it.
Hello Bluetti Support Team,
I would like to kindly request that the latest firmware update be pushed to my Bluetti AC180P unit.
Here are my current firmware details:
- IOT: v9046.01
- ARM: v2073.05
- DSP: v2077.06
Serial number: AC1802507003170224
I would like to enable the “System Switch Recovery” feature, but it appears that my firmware version does not yet support it. Could you please push the update that includes this feature to my device?
Thank you very much for your assistance.
Best regards.
Hi @4montIntra and @Pletenets, We’re pleased to inform you that we’ve improved the first version of the firmware and developed the second version, ARM v2140.88. The new firmware optimizes the system’s memory function, which helps avoid activating unnecessary outputs.
You can perform the upgrade at your convenience. After upgrading, please contact us to remove the upgrade notification. Then, could you help us test the performance of the new firmware? We’re looking forward to your feedback.
Hi @Pletenets, We have indeed consulted the Technical Department and R&D Department multiple times, and it has been confirmed that there is no way to develop firmware for controlling the fan operation as per your request.
When the power is connected, the fan will start automatically for self-testing.
We believe that as long as the power station can charge and discharge normally, this is a normal phenomenon and no additional handling is required.
Hi @Caique, We have rolled out the ARM: v2073.05 firmware to all AC180 users(low voltage area) in bulk. Once you upgrade to this firmware, you will gain access to the “System Switch Recovery” feature.
Please confirm whether you have received this firmware update, and make sure your account is properly registered and bound.
If you cannot see the firmware update prompt, please provide a screenshot of your firmware version page.
Привет
Я только что обновил прошивку на .88
Как Вы и просили
Что сразу заметил,это то что при включении станции и изменении режима ups ,без моего участия сами включились AC and DC🤯
Это не нормально
Я их выключил в ручную и потом снова при смене режима UPS они включились.
Но когда я включил AC ,то при смене режима ups DC не включалось.
Но теперь самое интересное,это то что моя проблема с включением вентилятора,о которой я писал Вам пол года изменилась,теперь в режиме ups custom вентилятор периодически стал выключаться, раньше работал постоянно,когда была включена сеть.
Не знаю связано это с прошивкой или с тем ,что у меня дома прохладней стало
Но если дело в прошивке,то обратите на это внимание.
Если есть возможность,что бы мне вернуть прошивку предыдущую, проверить работу вентилятора, что бы знать, связано это с температурой?Но по прежнему,кода отключена сеть,то вентилятор практически не работает ![]()
Включаю сеть,через минуту включается вентилятор и работает практически постоянно,при той же нагрузке
Проверил,так и есть при смене режима ups включаются AC and DC
