Привіт, надішліть мені посібник з оновлення мікропрограми, дякую.
Привіт у мене ще проблема з додатком BLUETTI на IOS 17.5.1. я зареєстрований, але коли входжу відписує система акаунту не існує, а також не приходе код ретифікації. Тому як я може оновити нову мікропрограму на AC180P ?
Hello, please send me firmware update for AC180P (random shutdowns):
AC180P2335001748844
ARM: v2089.02
DSP: v2088.02
BMS: v1039.01
Thanks!
Hi @BLUETTI_CARE !
Please send me me too firmware update for AC180P (random shutdowns):
AC180P2349002404872
ARM: v2089,03
DSP: v2088,02
BMS: v1039,01
Thanks!
Hi,
Also the same…
AC180P2344000533933
ARM v2089.02
DSP v2088.02l
BMS v1039.01
Thank you in advance!
Dear,@BLUETTI_CARE my Bluetti completely shuts down when electricity goes off. I have to turn it on manually and then all works fine. Pls push this new firmware for me too
AC180P2352000158344
ARM v2089,03
DSP v2088,02
BMS v1039,01
Hi @BLUETTI_CARE !
AC180P2335001504582
ARM: v2089,03
DSP: v2088,02
BMS: v1039,01
Thanks!
Hello @BLUETTI_CARE ! I have a problem with turning off when its in UPS mode and when its 100% charged
Can you send the update for my firmware please :)
AC180P2348001093775
ARM v2089,02
DSP 2089,02
BMS 1039,01
Hello @BLUETTI_CARE
I have faced with the same problem
AC180P2349000455427
ARM v2089.02
DSP v2088.02
BMS v1039.01
Please push new firmware for my device as well, thank you!
@BLUETTI_CARE
When at 100% battery and losing power from grid the station just shut downs by itself. Could you please also push this firmware to me?
AC180P2335001430970 ARM: 2089.02 DSP: 2088.02 BMS: 1039.01
AC180P2344000539619
ARM: v2089.02
DSP: v2088.02
BMS: v1039.01
Thanks!
Please send a firmware update to my device. I have the same problem with my AC180P (turns off randomly in UPS mode). Thank you!
AC180P2341000295070
ARM v2089.02
DSP v2088.02
BMS v1039.01
Hello, i have the same problem. Can you please push update to my device?
AC180P2349000555718
ARM v2089.02
DSP v2088.02
BMS v1039.01
I want to receive updates for stable operation of the station in UPS mode.
Model: AC180P
Serial number: 2349002036789
ARM: v2089.02
DSP: v2088.02
Can you help me?
Hello, @BLUETTI_CARE
My client has two products with this problem:
AC180P2332001030357
ARM v2089.02
DSP v2088.02
BMS v1039.01
AC180P2332001023180
ARM v2089.02
DSP v2088.02
BMS v1039.01
Thank you.
Hello, I have the same issue. Could you please send me a new firmware with the fix? Thank you
SN: AC180P2344000659293
ARM: v2089,02
DSP: v2088,02
BMS v1039,01
SN: AC180P2344000983037
ARM: v2089,02
DSP: v2088,02
BMS v1039,01
Hello, thank you for your regular support!
I have the same situation as @alex-bes . Shut down and noise. Can you send the update to me directly?
AC180P2335001680622
ARM-v2089.02
DSP-v2088.02
BMS-v1039.01
Hello @BLUETTI_CARE ! Please send a firmware update to my device. the same problem. random shutdown in UPS mode.
AC180P2344000817521
ARM v2089.02
DSP v2088.02
BMS v1039.01
Hi! @BLUETTI_CARE
I have the same problem. Please, send me a new firmware to fix it.
AC180P2349001664011
ARM 2089.02
DSP 2088.02
BMS 1039.01
Please, help me to fix this issue.
