Exactly the same problem here.
Shutdown occurs only at 100% SoC but sometimes it is seemingly at random, without grid power loss.
Setting sleep timer to never does not resolve the problem. ECO mode is off. No alert/error messages are provided through the app.
Good day. I have the same problem. Shutting down the station immediately after cutting off the mains power supply at 100% battery charge. Eco mode is off.
AC180P2349001448270
SN 2349001448270
AMR v 2089.02
I’ve bought the second AC180P and as long as the first one works perfectly on 2088.04 firmware, I would like to get the new version and on a new one. Thank you!
AC180P2349000567444
ARM 2089.02
DSP 2088.02
Yes, @moni , this problem was on out-of-the-box 02 firmware and migrated to 04 firmware.
Please, @BLUETTI_CARE , address the fan issue with the fan speed/cooling logic during small loads under 15 watts.
Hi, My AC180 is now quite old and I don’t use it very often but, I’m having the same problems as many others. The firmware is also old but it doesn’t show there are any updates available. Does everyone have to request an update individually? This would seem crazy!
AC1802315000335572
ARM V2074.07
DSP V2078.08
BMS V1033.12
@LeadDog AC180 and AC180P are different stations and the firmware for them is not compatible with each other. I think it’s better for you to either find a similar topic for AC180 or create a new one.
@BLUETTI_CARE How I will notified about sending me new firmware? Check for updates in Bluetti APP ?
Because you wrote “The above request will be processed in 24 hours” but there is no updates.
Good afternoon, today the power went out when the computer was working through a station connected to the network, and it turned off. ECO was turned off.
Can you send me an update?
AC180P2349000700978
ARM v2089.02
DPS v2088.02
