Water heater/boiler package
Hello dear Bluetti community
I recently discovered Power stations World and hey i loved what it offered so i tried an entry level from bluetti brand called “EB3A” it powers pretty much everything i need and i love it but I have found an issue i was hoping you guys or maybe bluetti team can help me out i have a zwc28 bosch MFA waterheater/boiler/package its gas powered but still for ignition fans and such needs AC 220v 50hz power.
long story short so i connected it to my bluetti it started and draws about 150-170w of power max, works for couple mins i hear lighter going off, powers on i hear the flame everything seems to be working but sadly after couple mins i get an error called “EA” i tried switching to 60hz it returned C6 error which is related to fan so i switched back to 50hz and its still causing EA error, this error according to my research in this datasheet Handleiding Junkers ZWC 28-3 MFA (pagina 1 van 48) (Nederlands) (used AI for translation and asked it to look for this error for me) is related to ignition, i found it to be correct since the flame LED even tho device turns on it wont light up but when i use wall outlet it works fine and it lights up, there is no short there is nothing weird happening to EB3A it seems to powering the device fine but the boiler giving out errors clearly not liking the power that its taking from EB3A
I was out of ideas so i thought maybe you guys kindly can help me with a solution maybe this is software related ? i tried a lot of suggestions that AI gave me but none of them worked like adding resistive load while using the device and so on.
I really really want this to work bluetti already powering 99% of what i need if i solved this i would give bluetti a perfect 10!
Sorry for the long read and thank you in advance.
The model that i got is a TYPE G outlet 220v version.
Hi @Sorenalike, We take your feedback very seriously. We consider that the peak power of the water heater exceeds the load range of the EB3A.
It seems that your water heater is displaying the error code EA, is that correct? Please consult the water heater seller to inquire about the meaning of the EA error code.
In addition, please log in to the Bluetti app and check if there is an “!” in the upper right corner. If so, click on it to obtain the error code, and we will troubleshoot based on that.
You can also press and hold the AC and LED buttons on the EB3A unit when the issue occurs to get the error code.
Thank you for your response, there are no errors from eb3a and the boiler error is ignition related i included data sheet as well
Max power that boiler uses is 180w without any surge beyond that, i explained in details what the issue is on my main post.
This boiler is gas powered so it uses small amount of electricity.
I saw this post today but idk how safe his solution is…
Ok i solved the issue, it was indeed grounding issue, this is what i did, i bought a uk type g plug then used the ground cable and connected earth cable to the plug and other side of the plug wire is connected to the waterheater body and it worked, it is recommended to connect the earth to real earth as well but i would assume since my boiler also screwed into the wall it is basically a real ground
I am writing this here for those that may have similar issue in the future, good luck guys
