Should you fully discharge after updating firmware on AC200L and B210?
I updated the firmware for my AC200L and Google’s AI summary is saying I should also discharge it to zero after the update. The app guide makes no mention of a full discharge. Should I fully discharge the AC200L after firmware updates?
Assuming that is the case, I was going to do that, then charge the AC200L to full, then attach the already fully charged B210 and update the firmware on that as well, then discharge to zero and fully charge both. Would this be the proper procedure?
No. If you observe the attached link the AI is referencing in the summary its this one: Do I need a firmware update and how do I get it?
You don’t HAVE to do a full discharge recalibration. No harm no foul if you do decide to do it though. If anything, the most important thing to do is ensure you have enough battery (or the unit plugged into mains) before performing a firmware update so it doesn’t die.
Yeah, I’ve seen a lot of forum posts mentioning full discharges so I just wanted to check :P. Thanks!
