Problem with New AC180P
My new AC180 shuts down when powering a 1300W Nespresso Essenza coffee machine. ECO off. Power Lift on.
The AC180 is stored in my motorhome inside a small cupboard. The outside temperatures of late have been around zero, hence the inside of the motorhome is cold. The AC180 operates a 600W milk frother no trouble. When the milk has heated and the frother removed from the AC180, I then connect the Nespresso machine. Almost immediately it shows an overload error and the power drops to zero. This happens with and without the power lift activated.
I have tried it in the motorhome, and it occurs even when the temperature is around 8-10 degrees. Interestingly this does not happen inside the house. It will run the Nespresso inside the house, but that is not what I bought it for. I bought the AC180 on the understanding that it would power the coffee machine while off grid. This is clearly not the case when the temperature is in the zero to 10 degrees range.
AC180 232 100 114 439 9
ARM V2074.07
DSP v2078.06
BMS v1033.12
Clearly, the AC180 is not doing what is designed to do. This should not be happening for a new machine straight out of the box. Advice and/or updated firmware please.
@BLUETTI_CARE Dear team!
I had been running AC180P in a UPS mode for the fridge, TV, and PS5 for almost a month with no issues! This is considering a very harsh condition here in my place, the grid goes off several times a day.
And now, it’s been a couple of days since I also started nothing the same issues:
  1. There is a high chance system will shut down when the grid goes off;
  2. Sometimes it shuts down just randomly.
Also, as some other members mentioned here, I experienced an issue with fans going crazy and staying on until I reboot the unit. This is under just a dozen or two watts of AC load. The until is silent after rebooting under the same load.
S/N: AC180P2349002235901
Now in worrying, Isn’t this a hardware degradation of some sort? The usage conditions didn’t change but the system became unreliable in the UPS mode. Will and how exactly the firmware upgrade fix the issue if so?
Please push an upgrade for my unit if you think this will help.
@BLUETTI_CARE I have just noticed another problem with my unit: It is stuck in “silent” charging mode. I can change it to neither “standard” nor “turbo” via the app. It just says nothing and just stays in “silent” mode after I attempt to change it.
This way I won’t be able to fully reach the unit until the next time the grid goes off. Very disappointing.
@OleksiiK Доброго здоровʼя! Підкажіть, чи отримали ви нову версію прошивки. Маю таку саму проблему як у вас один в один
@darkside Добрий вечір!
Ні, поки що не отримав, чекаю відповіді.
Hey, @BLUETTI_CARE ,could you also push new 04 firmware to me? Have the same issue. Thanks!
AC180P2349002428173
ARM: 2089.03
DSP: 2088.02
BMS: 1039.01
Проблема використання станції в режимі ДБЖ. Періодично вимикається. Надішліть оновлення AC180P2344003056736
АРМ V2089.02
DSP V2088.02
BMS v1039.01
Hello, @BLUETTI_CARE, have same issue with UPS mode with another my stations.
Please push latest available firmware on my devices:
ARM V2089.02
DSP V2088.02
BMS V1039.01
AC180P2335001483324
AC180P2335000465706
AC180P2335001064970
Thank you
Hi @BLUETTI_CARE , have same issue with UPS mode
Please update my device
AC180P2349001151930
ARM v2089,02
DSP v2088,02
BMS v1039,01
Thank you
Hi @pgard7109 , I suppose that the AC180 has activated protection based on the ambient temperature to prevent damage to the battery from low temperatures.
We do not have new firmware that can enhance battery performance in low temperatures. Developing such firmware might impact the battery’s lifespan. Therefore, we recommend using the AC180 in a suitable temperature environment.
Dear @BLUETTI_CARE ,
Just bought 1 more AC180P. Same issue with UPS mode again. Could you, please, send me firmware updates as well?
Thanks in advance!
Serial number: AC180P2332001230118
ARM: v2089.02
DSP: v2088.02
BMS: v1039.01
Hello @BLUETTI_CARE.
There is an issue with the operation of the UPS. After a power outage, the AC180 turns off. Please send an updated firmware.
AC180P2344003038762
ARM - 2089,02
DSP - 2088,02
BMS - 1039,01
To all AC180P owners:
The firmware version DSP2088.03 that solves this AC180P issue has been pushed to everyone’s AC180Ps, please kindly upgrade.
Notes:
  1. All firmware versions starting with 2088 can be upgraded.
  2. Those who have not been pushed the 208804 version before can upgrade, those who have already upgraded to 208804 will not receive the update.
  3. The batch-pushed 208803 is the same as the previously targeted 208804 version, solving the same issue.
Thank you very much @BLUETTI_CARE
AC180P2352000204668
ARM v2089,03
DSP v2088,03
BMS v1039,01
Thank you
Hi @vvien, I have applied to upgrade your DSP to our IT department. They will push the latest version of firmware to your machine in 24 hours. Please upgrade it tomorrow.
Hi @BLUETTI_CARE
Sorry for bothering but it seems I have the same problem on the latest firmware. Could u help me please ?
Sn AC180P2428000165186
Thanks in advance
Thank you
Updated now. Will test in a few days and let you know if everything works fine
Hi @Mrwhite, we have applied to upgrade your DSP to our IT department. They will push the latest version of firmware to your machine in 24 hours. Please upgrade it tomorrow.
Hello @BLUETTI_CARE!
I’m owning AC180P and facing the same issue with UPS mode. When it’s charged after a while it just turns off. Eco mode is disabled, it was connected to the fridge with 100-130w consumption.
Could you send a firmware update to me as well? I would appreciate your support!
Serial Number:
AC180P2428001652792
Firmware Versions:
IoT: v9046.01
ARM: v2125.02
DSP: v2126.02
BMS (Pack 1): v1048.03
