The problem described is with an AC180P device, which is connected to an wall outlet and functioning as an UPS for a computer. The battery is fully charged and Eco mode is turned off. Despite this setup, the station periodically shuts down, displaying error codes E090 and E000. Load is about 150 w per hour. @BLUETTI and @BLUETTI_CARE
Hi @Valentyn1
Sadly, the error codes are not provided in the manual.
Do you know if it happens after a specific time? Or is it random? 150W should be easily handleable for such a unit.
What I would check is, if the unit has enough surrounding are. So it shouldn’t be in a wardrobe or in direct sunlight. These units can get really hot when in sunlight or dont get “fresh” air to cool down.
Otherwise, maybe @BLUETTI_CARE can help with the error codes.
Greetings
@Valentyn1 Please provide me with the SN and the firmware version of your AC180P. We have a new firmware version for you test.
