Newly purchased Bluetti Elite 100 V2. will not charge
I purchased my Bluetti Elite 100 V2 on November 27. I charged it to 100% and left it in that state for about a week. I then connected it to a 12V refrigerator and let it drain the Bluetti completely. Since then, I have not been able to recharge it. I’ve tried several times; sometimes the display illuminates briefly, then it shuts off. Sometimes it does not light up at all. Any insight would be appreciated.
Може це чимось допоможе
Try charging with a 12-60V DC power supply through the DC input (XT60). This can be done from a solar panel, a car cigarette lighter socket (requires a cable), or a 12V/24V…48V battery (observing polarity), or a DC power source up to 60V.
But be careful not to reverse the polarity and do not exceed 60 volts.
Once the station turns on, you can continue charging from an AC outlet. Do not load and use the 1A setting in the app.
