My new AC180 keeps shutting itself off…HELP! I have disable ECO mode for AC because I really need the AC to stay on. It seems like it turns itself off when the battery hits 100%. When I say off I mean the display goes blank, the DC power goes off, the AC power turns off, and it won’t allow me to connect via the app and bluetooth. When I manually turn the unit back on it works fine.
I’m powering it primarily off of solar. I really really need the AC to stay on…please help!
Here is all my info. My SN is AC1802328000229002. The BMS is v1033.06, ARM is 2073.04. The DSP is v2077.06.
Note that when I set the Auto Sleep to “Never” the problem goes away. However that means the display is always on which is not desirable. Thanks!
Hi Same here, the problem still persist after update @ 24 April , 2024 version .
The AC180 P shut off completely after 30 min ( or slight different) with 100% full charge with load attached , the 30 W fan. ( dont sayt check ECO Mode, we know that is OFF!)
While still not reliable machine ?
Imaging that your are rendering 3d model or video , via Bluetti output charged at 100% coz you are afraid of loosing power, the M/C shut off, lose all your work !!!
