I’ve run into a situation today where sometimes the bluetooth connection from one EP500P gets into a bad state, and looks like is not stable from this EP500P. Other EP500P are fine at the same time. I’m relying on the bluetooth to control the EP500Ps charging/grid state.
The issue is not phones or computer connecting to the bluetooth but rather the EP500P. From a computer I can see the device is still discoverable when this happens, but bluetoothctl shows connection and disconnect immediately from the device when attempting to connect to it.
On the EP500P I’ve turned off the bluetooth and turned it back on after waiting ~30 minutes. I’ve even tried shutting off wifi and bluetooth to resolve the state. However, nothing can reconnect to the bluetooth after enabling again (phones, computer). The only way to resolve this is to completely power cycle the EP500P, which is a major inconvenience (as it powers the house).
I see that I’m on the latest IOT for replacement EP500P2322xxx (v9041.06). @BLUETTI Is there any other method to restart the communications (bluetooth/wifi) completely without having to power down? Can the firmware do this automatically these are shutdown for a specified period (lets say exactly 5 minutes)?
Ideally, the root cause needs to be found, but please let me know if there is a workaround, as this is causing a lot of frustration. Only one unit seems to have this issue.
Hi @PowerMat, Our product development team has addressed it by creating new IoT firmware.
Could you please provide your EP500PRO’s SN number? We want to fix this problem by upgrading the firmware.
@BLUETTI_CARE Thank you for pushing the IoT firmware this past weekend. I have updated from 9041.06 → 9041.10
I have been running the update for ~3 days, and the original bluetooth connection issue seems to be resolved as I have yet to encounter the issue. Thank you for pushing the firmware update after our direct message. I believe the connection is more stable than on the original crowdfunded EP500Ps that I have, as I’m logging the retries. If the original EP500P gets into trouble I can just disconnect and reconnect just fine though.
If anyone else is running into similar bluetooth issues it appears the IoT updates could resolve the problem.
Interesting topic, I have had also a BT connection problem a few weeks ago, my EP500pro has also a BT connection error and while I´m using HomeAssistant to track the device, the emergency charging via smart plug was not triggered.
Result: device battery goes to zero and my connected fridges shut down.
Takes me a little bit of effort to charge the device with grid and restarting all manually, during this time my fridge was offline, but I has used manual power with a cord. Luckily I was at home and see it in my HA dashboard.
Until then the EP500pro works fine and I have no new issues until now. (fingers crossed)
But btw I also made a software update after the problem, maybe you delivered the new BT FW for all devices?
Or shall I check again for device updates? actual states: app says it´s actual!
IOT v904,10 ARM v4039,5 DSP v4055,03 BMS 1020,01
@BLUETTI_CARE I’m having this issue again with the same EP500P as listed above, the bluettooth gets in a bad state from this specific EP500P, this has happened around 3 times in the past month.
I’m relying on the bluetooth to control the EP500Ps charging/grid state. The issue is not phones or computer connecting to the bluetooth but rather the EP500P. On the EP500P I’ve turned off the bluetooth and turned it back on after waiting for a few minutes. I’ve even tried shutting off wifi and bluetooth to resolve the state. However, nothing can reconnect to the bluetooth after enabling again (phones, computer). The only way to resolve this is to completely power cycle the EP500P, which is a major inconvenience (as it powers the house), and is also running split phase mode.
Has the IOT firware regressed the fix for the initial problem? I know that it had been working well for a long while, but then I had upgraded newer firmware when we had an issue with another unit.
I see that I’m on the latest IOT for the EP500P2322xxx (v9041.12) and there is no newer update available. This is causing a lot of frustration and only one unit seems to have this issue. Would you please provide a way to workaround the issue if a fix is not available?
Hi @BLUETTI_CARE I’m still having this issue that is reported, I’ve DM’d this info below over a moth ago but I’ve had bluetooth issues persists on this same unit, and have to shutdown the unit to fix it twice since my second report on May 21st 2026
