Hello, please tell us the firmware version of your device.
Hi all, for Ukrainian users who are unable to perform AC charging under low grid voltage conditions, please click the link below to fill in your SN, DSP version and other relevant information.
https://feedback.bluettipower.com/questionnaire/69707f00fbdb8877850611a2
We will push the new firmware to resolve this issue. Thank you for your cooperation.
Hi @BLUETTI and @BLUETTI_CARE,
I’m experiencing the exact same issue with my AC60P.
I really hope this problem can be resolved.
Thank you in advance for your help!
AC60P2352000105377
ARM v2090.04
DSP v.2075.04
BMS 1 v.1042.03
BMS 2 v.1044.04
Hi. @BLUETTI
I don’t see any updates. Perhaps I misunderstood you, and you’re expecting more information from me. I’m providing it.
AC1802435005268945
IOT v9046.04
ARM v2124.04
DSP v2126.03
BMS v1052.03
adaptive mode OFF
AC1802422000993707
IOT v9046.04
ARM v2124.04
DSP v2126.02
BMS v1052.02
adaptive mode ON
AC1802433002019687
IOT v9046.04
ARM v2124.04
DSP v2126.02
BMS v1052.03
adaptive mode OFF
AS1802435004959272
IOT v9046.04
ARM v2124.03
DSP v2126.03
BMS v1052.03
adaptive mode OFF
I’m from Ukraine and I am also has charging issue on 175-190V.
Also my station turn off randomly when losing power from grid the station just shut downs by itself, when i use it like UPS.
Could you help with a new firmware that would solve this problems?
АС180Р2344000578339
ARM V2089.02
BMS V1039.01
Issue with Low Grid Voltage in Ukraine Preventing AC Charging - Announcements - BLUETTI Community Hello, please fill in your information in the form as instructed in the post.
Hello @BLUETTI_CARE @BLUETTI
I have the same issue with charging in Ukraine when grid voltage is 180-190
Please push updated firmware to allow charging on low grid voltage for my AC200PL and AC180P.
AC200PL:
AC200PL2426003130879
IOT v9041.10
ARM v2140.05
DSP v2130.13
BMS v1056.03
B210:
2409000279369
BMS v1064.01
AC180P 2349001976816
ARM 2089.04
DSP 2088.04
@BLUETTI_CARE I apologize, but I was only able to update the IoT firmware . It seems that the DSP needs to be updated first. Can you please check for my device?
SN: AC200PL2412000185472
Current firmware
IOT: v9041.10
ARM: v2140.04
DSP: v2130.09
BMS: v1056.02
But the update buttons themselves are no longer available.
Hi all, good day!
Thank you for your cooperation. Recently, we have received numerous requests from users who filled out the link below to submit firmware push applications.
Please note that some users have not filled in the SN code correctly. The SN code should be the number starting with the model name, which can be found on the device’s back or in the app. For example, the correct format of the SN code for EB3A is EB3A + 13 digits.
We will first push the existing firmware for your device. If the relevant firmware is not available, we will submit the request to the R&D department to develop a new one and push it to you once the development is completed. This process may take some time. If you are concerned about the waiting period, you may purchase a voltage regulator for temporary use first.
If possible, please fill in your forum username to facilitate our follow-up communication with you at any time. If you have not registered a forum account, you may use a family member’s or friend’s forum username instead.
Hi @AndriiSokolan, after verification, we have indeed pushed the latest firmware DSP213011 to your AC200PL. Could you please confirm this on your end? If possible, kindly provide a screenshot of your firmware update page for us to verify the SN code and other relevant information.
Please ensure the device is account-bound and connected via Bluetooth during the update process.
Hello @BLUETTI_CARE and @BLUETTI,
I am writing from Ukraine. Due to frequent grid instability, the voltage in my house often drops to 180-190V. Because of this, my power stations stop charging from the grid. I’ve seen on this forum that special firmware updates (DSP) can help lower the charging threshold.
Please push the latest updates to my devices. Here are the details:
- AC180P
SN: ac180p2342000694373
Current versions: ARM v2089.04, DSP v2088.03, BMS v1039.01
- AC50P
SN: ac50p2446000643023
Current versions: IOT v9046.04, ARM v2171.01, DSP v2169.03
- EB3A
SN: eb3a2242002456117
Current versions: ARM v2063.03, DSP v2052.11
Thank you for your support!
Please fill out your device information in the online form linked in this post, and we will process it collectively. If you have any questions, please feel free to let me know.
Dear @BLUETTI_CARE @BLUETTI
I submitted the form on Thursday. When do I expect an updated firmware?
AC200PL2426003130879 and AC180P2349001976816
Hi @Iusachev, we’ve consulted our technical department regarding this matter, and they informed us that your AC200PL already has the latest firmware installed, so no new firmware can be pushed for the time being. Please enable Grid Self-adaption and then adjust the parameters gradually until they match the grid voltage.
As for your AC180P, we have pushed the firmware DSP208804 to your device. Please upgrade it and then enable Grid Self-adaption. We hope this helps.
I am also from Ukraine and face the same issues with low voltage coming from the utility.
Can you please schedule an update for my AC200PL as well?
SN: AC200PL2446002135417
IoT: v9041.10
ARM: v2140.05
DSP: v2130.13
Thank you in advance!
Hi @BLUETTI_CARE
SN: AC200PL2402000552385
IoT: v9041.10
ARM: v2140.05
DSP: v2130.13
Hi @ArtTheBell, we would like to help you.
Hi @Vadym5, thank you for contacting us. It seems you have clicked our link and filled out the form before. Is that correct?
