Issue with Low Grid Voltage in Ukraine Preventing AC Charging
Hello, you can view the information on your mobile phone.
Hello. Please tell me how long it will take to send the firmware to my device after sending the completed form? Thank you for your support.
We will push the firmware within a day at the latest, excluding weekends. If you have any questions, please feel free to let me know.
@BLUETTI / @BLUETTI_CARE , hello. I’m from Ukraine too.
Please help me:
My EP600 station won’t charge from the grid because it’s currently at 175-185 volts. It needs at least 197-200 volts on each of the three phases.
Please help me update the firmware, otherwise I can’t use the station now.
EP600
Serial# EP6002251000683334
DSP v5003.24
Grid Voltage 175-195v
Thank you for the prompt update deployment. I have successfully installed it and it really helped.
However, I would like to clarify the specific verification process for other users, as “view on mobile phone” is quite vague. Since I did not receive any email or push notifications, here is the workflow that worked for me:
  1. Internet Connection: Ensure your mobile device has an active Internet connection (Wi-Fi or mobile data). The app cannot identify that an update is available without it.
  2. Manual Check: Open the app, connect to the power station, and navigate to the Upgrade menu.
  3. Target Firmware: The update must be available specifically for the DSP firmware. Note: If you do not see an update listed there, it means your request likely hasn’t been approved yet, repeat these steps later.
  4. Result: After applying the update, the unit now successfully charges even when grid voltage drops below 190V.
Thank you for doing this @BLUETTI . I see so many customers in Ukraine with this issue. This will make it easier to get help.
@BLUETTI hello. I’m from Ukraine too.
Please help me:
Please help me update the firmware, otherwise I can’t use the station.
EP600
DSP v5003.24
Hi, same issue.
AC300
DSP Firmware Version 4053.03
Serial Number AC3002313002234063
thanks in advance
Please fill out your information in the form on this forum. We will address these issues collectively, and it will be processed within a day at the latest.
Hi @BLUETTI
I own a BLUETTI AC300. Fortunately, I don’t need this firmware update right now, but I would like to understand these aspects for future use and how the new firmware handles such challenges.
  1. “Low input voltage”
    Is it safe for the AC300 to operate and charge when the grid voltage drops to around 120 V, while the nominal voltage should be 230 V?
  2. “Sudden voltage fluctuations”
    How does the AC300 behave if the grid voltage frequently changes, for example:
    160–190 V, then suddenly drops to 140 V, and then rises back again?
    Are such fluctuations dangerous for the power station in the long term?
  3. “Charging behavior at low voltage”
    When the input voltage is low, does the AC300 automatically reduce the charging power?
    In other words, is it correct that the lower the voltage, the fewer watts it will draw?
  4. “Grid frequency and waveform quality”
    Sometimes the grid frequency drops to about 49 Hz, and the sine wave quality is not very good.
    Is this safe for the AC300, or could poor waveform quality and frequency deviations cause any damage or accelerated wear?
  5. Generator compatibility and power quality
    With this firmware installed, are there any known issues when charging the AC300 from a generator?
    I’m asking because generators can sometimes produce unstable power (voltage fluctuations, frequency variations, or a distorted sine wave).
    Does the firmware handle such conditions safely, or are there any recommended settings or limitations when using a generator?
Thank you in advance for your clarification and support.
Dear @BLUETTI
I submitted the form on Friday. When do I expect an updated firmware?
Updated. Now its works. Thanks.
Hello, have you received the firmware update information? If not, please provide me with your device’s SN code.
Hello. Unfortunately, I can’t see any firmware updates?
EB3A2246001962012
Hi @Serginnio, we are aware of this issue and are actively developing a new firmware update. It will be pushed to your device as soon as the development is completed.
Thank you for your patience.
Hi @BLUETTI
I left a request for DSP update on Saturday, 24.01.2026 through the questionnaire form above. Today I’ve noticed that my SN could get letter ‘O’ instead of digit ‘0’ in it, so I’ve posted another form response.
Just in case, I’ll repeat it here:
Model: AC180P
SN: AC180P2342000067058
DSP: v2088.03
ARM: v2089.04
Could you please check if the update was sent to my app?
Thanks in advance,
Volodymyr
Hello, we have registered you for the new firmware update, but it hasn’t been pushed out yet. Please wait patiently.
Hello everyone, I contacted the link provided on Monday, but they still haven’t sent the firmware. Can you tell me when I can expect it?
AC2P2443001906412, DSP V.2136.01
Dear @BLUETTI team,
Any news on my device EB3A2246001962012 ?
Thank you in advance.
