Bug Tracking for BLUETTI AC SERIES
Hey everyone!
This thread should be use for known bugs in the firmware and the latest firmware updates for the AC Series of Bluetti Powerstations.
For fill this thread with information, i need your help!
Please report your current unit, Region and installed firmware. If you facing any bugs with you unit, please also provide this informations with a error description. If the same error is reported multiple times, i will include this as “known bug” into this thread.
Hope this leading to more transparancy within the community and maybe is also a great help for the bluetti devolopers to see what problems some firmware may have and fix them much sooner.
Please use this kind of format to comment this thread:
Unit name: ACxxx
Region: EU/US/CA/JP etc.
Current firmware: ARM: xxxx, BMS: xxx, and so on.
Current Problems: Please provide a short description of what you problem is currently
Thanks in advanced to everyone who is helping!
Overview
AC60
Region: EU
Current Firmware:
Known bugs:
Region: US
Current Firmware:
Known bugs:
Region: CA
Current Firmware:
Known bugs:
Region: JP
Current Firmware:
Known bugs:
AC60P
Region: EU
Current Firmware:
Known bugs:
Region: US
Current Firmware:
Known bugs:
Region: CA
Current Firmware:
Known bugs:
Region: JP
Current Firmware:
Known bugs:
AC180
Region: EU
Current Firmware:
Known bugs:
Region: US
Current Firmware:
Known bugs:
Region: CA
Current Firmware:
Known bugs:
Region: JP
Current Firmware:
Known bugs:
AC180P
Region: EU
Current Firmware:
Known bugs:
Region: US
Current Firmware:
Known bugs:
Region: CA
Current Firmware:
Known bugs:
Region: JP
Current Firmware:
Known bugs:
AC200Max
Region: EU
Current Firmware:
Known bugs: Current Update may have Problems with connected extra Batterie such as B300. Dont know about the region.
Souce:
Region: US
Current Firmware:
Known bugs:
Region: CA
Current Firmware:
Known bugs:
Region: JP
Current Firmware:
Known bugs:
AC500
Region: EU
Current Firmware:
Known bugs:
Region: US
Current Firmware:
Known bugs:
Region: CA
Current Firmware:
Known bugs:
Region: JP
Current Firmware:
Known bugs:
AC300
Region: EU
Current Firmware:
Known bugs:
Region: US
Current Firmware: ARM: 4032.09, DSP: 4031.16
Known bugs: The “total kWh generated by your PV” value is too low (approximately 50% of true value), fixed in ARM 4032.10; Significantly reduced PV power generation when high AC output load is present, fixed in DSP 4031.25
Region: CA
Current Firmware:
Known bugs:
Region: JP
Current Firmware:
Known bugs:
AC200P
Region: EU
Current Firmware:
Known bugs:
Region: US
Current Firmware:
Known bugs:
Region: CA
Current Firmware:
Known bugs:
Region: JP
Current Firmware:
Known bugs:
@BLUETTI_CARE @BLUETTI Can you pin this on top? Thanks
Unit name: AC300
Region: US
Current firmware: ARM: 4032.09
Current Problems: The “total kWh generated by your PV” value is too low (approximately 50% of true value), fixed in ARM 4032.10
Unit name: AC300
Region: US
Current firmware: DSP: 4031.16
Current Problems: Significantly reduced PV power generation when high AC output load is present, fixed in DSP 4031.25
Unit name: AC180
Region: EU
Current firmware: ARM: v2124.02, DSP: v2126.02, iOT:V9046.01
Current Problems: Screen all lights are on
