Bluetti AC180 Display screen gone crazy
After the 3rd day of ownership i plugged in the Bluetti to be charged. The display screen went crazy and everything was lighting on and off. The voltage jumps around from the actual rate up to 199. The input voltage is jumping all around from all zeros to 99999. The overload,Heat and every other thing is lighting on and off. The only way i can tell the status of the generator (Current power reserves,Charging etc,) is with the app. What is going on??? Oh the device will charge up and can be usd normally but the display is completely worthless.
I recommend taking a video showing both the phone app working fine and the display screen going crazy together in the same view, and then send it to your local country Bluetti support email. They may have instructions to fully reset the AC180.
Hi @otrkid70 , I agree with @aaron33 's opinion. Please send the video to our after-sales service email. We will check if there is a firmware update that can resolve the issue. If not, we will need to arrange for a repair. The US customer service email is service@bluettipower.com.
Hi @otrkid70
i’ve seen a similar problem, where the display of the unit was just “froozen” with everything was displayed. They suggest to reach to the after sale support for assistant
Same issue to me, when I enable the station each label is blinking, but in application everything fine, so I assume it’s related to screen, maybe if someont from support can describe how to reset screen.
We have used an ac180 first used time and, now I push the power button on and and the whole display is messed up.
I’m pretty bummed about this, such an expensive device for which there is so much praise.
What can I do ? Since we are also going on vacation soon, I can’t wait long to send it back first and then wait quite a while for it to be repaired.
I would like to hear which ones offer good service
Same issue here, hoping a firmware update will fix it. Does anyone know if that’s the case? Also what is the best way to do the update? Fully charged?
its best to be fully charged before any update as otherwise the update could fail part way through which can cause issues. I usually have mine plugged in too.
