AC500 WIFI disconnects then will not auto reconnect
HI
The AC500 will connect to Wi-Fi, however it only stays connected for a short period (Usually less than an hour) then it disconnects and it does not reconnect unless I manually select ‘OFF’ then ‘ON’ again in WIFI settings.
I have a good Wi-Fi signal where the AC500 is located so it does not have a problem initially connecting. The issue is staying connected and it never reconnects once it disconnects itself. The AC500 is in the exact same place in my house as the former AC300 which never presented this problem.
Here is a short Video clip I have uploaded to YouTube so you can see the issue.
Here are my network settings
Your help here is as always very much appreciated
Dean
@Deano Thanks for your video. May I know the IOT version of AC500?
Hi - Thankyou very much for getting back to me on this.
IOT Attached
Dean
@Deano The background has pushed the new IOT firmware to AC500. After upgrading the IOT firmware, please reconfigure the network and turn off the WiFi, then turn it on.
Hi I have updated the IOT firmware as instructed and rebooted / reconnected
So far today = V.Good :slightly_smiling_face:
I’ll post back here with any updates as I continue to monitor the ongoing connection
Dean
@Deano Thanks for your update.
