AC200PL with B500K
Hi @BLUETTI and @BLUETTI_CARE. Is it B500K supported with AC200PL? B300K definitely works great. Maybe new firmware should be released to have a support for relatively fresh battery support? Also should B300K and B500K works together with AC200PL?
Thank you for your inquiry! Here is the relevant information regarding the connections for the AC200L:
  1. The AC200L supports connecting up to 2 battery packs:
  • When connected to 1 B230, the capacity reaches 4096Wh;
  • When connected to 2 B300s, the capacity reaches 8192Wh;
  • When connected to 2 B210/B210Ps, the capacity reaches 6348Wh;
  • When connected to 2 B300Ks, the capacity reaches 7577.6Wh;
  • When connected to 2 B500Ks, the capacity reaches 12288Wh.
  1. Connection Limitations:
  • The AC200L is only allowed to be mixed connected with B300 and B300K, or with B210 and B210P. Other mixed connection methods are not permitted.
If you have any further questions, please feel free to reach out.
Thank you for your support!
Thanks for response! Currently i see a B500K in a list of batteries, but without a model, how it can be fixed?
Thank you for your response!
Could you please clarify what specific “model information” you are referring to? This will help us better understand your issue and provide a solution.
Looking forward to your reply!
