Hi everyone! I have a question about setting up a parallel power and backup configuration with Bluetti gear. I’m looking to connect two EP600 units along with four B500 batteries to get more output power. If anyone has any experience or a wiring diagram on how to do this properly, I’d really appreciate your tips
Hi @SzymonZ ,
I would recommend to read this Threat:
You will need a special cable set for this, which is available from Support/Shop. All the information you need can be found in the attached link …
For a first overview go to the Shop and search for EP600 / Tech Spec …
