Attached my new AC200P Power Station to the SP120 solar panel. Reads PV 24v and no amps
so not charging. I verified the mode is PV. Charge was at 34%.
35 volts is the minimum voltage required for charging to occur. This is not possible with a single SP120 panel and you need at least two panels connected in series for charging to begin.
I saw that requirement in the manual but since the bundle I purchased had only one SP120 I was hoping that was enough. Thanks.
