I have read many threads about the AC300 failing due to wiring errors. I want to make sure my understanding is correct.
I would like to use the AC300 as backup to the home main panel, but I am concerned about the neutral bar in the main panel being connected to the ground. Is the bonded neutral an issue if the AC power input to the AC300 is not used?
As I understand it, the problem occurs only if the AC power input to the AC300 is connected the same neutral as a circuit it is supplying power to. Am I correct?
If that is the only issue, can the AC300 be used like a generator supplying the home main panel as long as the AC input is unplugged. I have 1,920 watts of solar to recharge during the day.
