I have an opportunity to purchase a B230 expansion battery. I have an AC180 and the PV200 panel and, I wish to use the B230 to boost the 180. So if I purchase one of the DC charge enhancers. To charge the B230 with the PV200. What exactly is the cable or charger I need to get the best charge to the AC180 from the B230?
Found the amswer toy question with just a little more looking.
Have already ordered the cable I will need. Next I will order the DC charge enhancer after I get the B230.
I have this set up you need pd90 cable with 7909 and will charge your ac180 at 500 watts from b230 battery
Thanks, I ordered the cable you specified already. I appreciate the knowledge. I also want to confirm what you said about the B230 output being 500 watts to the AC180. Is that with the PV200 attached via the dc charge enhancer. Or is it just passing through whatever wattage the panel is generating?
Also in your opinion would it be safe to connect 600 watts of solar input? Given that the charge enhancer regulates the input to the B230.
yes I have bought cable pd90 to 7909 change ac180 at 500 watt thought b230 battery
