I have a question. Are these solar modules compatible with AC300?
PARTNER SECTION
ELECTRICAL DATA | STC*
CS3L 360MS 365MS 370MS 375MS 380MS 385MS
Nominal Max. Power (Pmax) 360 W 365 W 370 W 375 W 380 W 385 W
Opt. Operating Voltage (Vmp)33.7 V 33.9 V 34.1 V 34.3 V 34.5 V 34.7 V
Opt. Operating Current (Imp) 10.69 A10.78 A10.86 A10.94 A11.02 A11.10 A
Open Circuit Voltage (Voc) 40.4 V 40.6 V 40.8 V 41.0 V 41.2 V 41.4 V
Short Circuit Current (Isc) 11.40 A11.47 A11.54 A11.61 A11.68 A11.75 A
Module Efficiency 19.5% 19.7% 20.0% 20.3% 20.5% 20.8%
Operating Temperature -40°C ~ +85°C
Max. System Voltage 1500V (IEC/UL) or 1000V (IEC/UL)
Module Fire Performance TYPE 1 (UL 61730 1500V) or TYPE 2 (UL 61730
1000V) or CLASS C (IEC 61730)
Max. Series Fuse Rating 20 A
Application Classification Class A
Power Tolerance
- Under Standard Test Conditions (STC) of irradiance of 1000 W/m2, spectrum AM 1.5 and cell
temperature of 25°C
