I am going to need another PV350 for my AC200Max (bringing the total to two PV350’s), but I also need a solar panel for panel to charge my EB3A (…likely a PV200).
I’m very new at this, so I’m just wondering is there a way I can deploy the PV200 with the PV350’s to charge the AC200Max?
You can however use the PV350 to charge your EB3a if desired as the EB3a will only allow a max of 8 amps input. The most you will be able to input to the EB3a will be around 160 watts due to the 8 amp limitation so a 200 or one of your 350’s will work well.
You could also purchase another 350 and use three of them with your 200 Max if desired and if you have perfect sun and perfect conditions you could connect two of the 350s to the PV port and the third to the AC charging brick input port via a DO50s voltage enhancer for max input.
I would thing however, if you had three 350 panels connected in series to your 200 max you would be good to go with all three connected in series to the PV port.
No, your panel cannot have a greater voltage than the maximum input voltage spec. Damage will occur and your charging circuit will no longer function if you exceed the voltage limit
