I’m using 80 feet of 10awg and am getting about 10 watts of loss at that distance. I also have a duplicate set in 12awg and was getting a bit more loss with it but don’t recall the exact amount, maybe 5 watts more? Either gauge should be fine at 50 feet.
Terrific, I really appreciate your help!
I have a EB70s and plan to connect a Regony 200 Watt panel to it. Will this work? Plan is to hook up to cigarette lighter while driving, then run off panel while parked.
You have up to 700W using the Aviator plug for AC200P so no problem. You likely can use 8 100W panels with no worries as they don’t come close to 100% ever…just don’t exceed 700W charging.
