Do I need these … or might I need these, like in the future, for anything? I’m trying to figure out if these are any good to have on hand, for like emergencies. Thank you!
I believe having spares on hand is always a good idea. Especially if you are boondocking. Don’t forget to have the tool kit needed to replace the connectors.
If you are comfortable with replacing or installing them by all means they are a good idea. I would recommend having about three times more than you think you need though as you will find it easy to install the incorrect gender or piece and have to re-do the work a few times when first starting out.
Even if you don’t make your own cables, etc at some point you will have a panel or cable connector problem that may require replacment of the MC4 connector to resolve the issue. It is fairly easy to do and it is a good idea to learn how and keep a few spare connectors on hand. I ordered a 100 pack about 9 months ago and am down to about 25 left. I like to experiment with different cables, meters etc and they give me a lot of flexibility.
Here is an example of a kit that gives you a few connectors and a basic tools.
https://www.amazon.com/dp/B078B7N3WD/ref=redir_mobile_desktop?encoding=UTF8&aaxitk=bqKg4fV3nABpLbgQE8LY0w&hsa_cr_id=3782972350501&pd_rd_plhdr=t&pd_rd_r=ac2d1a82-ccba-47ec-ab78-9399a471ee22&pd_rd_w=vSXDF&pd_rd_wg=syq4J&ref=sbx_be_s_sparkle_mcd_asin_2_img
Thank you … both! Will do!
