I can’t get it to take solar input. I validated I have voltage at the plug and its setting around 115 voltage which is within spec, photos attached. Can anyone help? I have barely had it a month.
Sorry for the problem.
Is it normal when it was charged with AC charging and car charging? If these two charging ways are normal, it may be the problem of the MC4 to XT90 or XT90 to aviation plug.
@dvrtech Yea I’d try the car charging method with the correct setting applied and see what happens. If that doesn’t work, I’d assume it’s your aviation input port and you’d need to contact service.
