PV charging two AC500 in Split Phase connection
How do you connect PV input when using two AC500’s in split phase? Does each AC500 need to be connected to its own PV setup, or can I just connect to the Primary AC500 and it will charge both battery banks (Two B300S on each AC500)? Thank you in advance for your advice/solution.
