Hello together, as I want to use the AC inverter only during the night it would be great if the inverter can be programmed according to time or it may also makes sense to switch it on depending on Batterie SOC and PV input.
Hopefully this feature can be added in the next SW release.
The AC200Max itself doesn’t have support for this feature (yet, Bluetti? hint hint).
In the meanwhile you could accompany it with a Raspberry Pi that keeps connected via Bluetooth. With some not-so-difficult Python programming you could achieve your goal. I’m enthusiastic about this setup because I use it to monitor the AC200Max and to bridge it to MQTT to disclose the information (and control) to many available MQTT clients.
