Problem with New AC180P
Hello @BLUETTI_CARE after updating to DSP firmware to v2088.04 my device is working as expected, no shutdowns for 4 days so far.
Hi!
Having the same issue with the automatic shutdown (randomly) of my Bluetii AC180P (otherwise a solid piece of engineering). Please, provide me with the newest firmware (2088,04) upgrade to test it.
Many thanks
P.S. AC 180P2342000542085
ARM version v.2089,02
DSP version v. 2088,02
BMS version v. 1039,01
Dear @BLUETTI_CARE,
Please update software, my device is:
AC180P2349000781047
ARM V2089.02
DSP V2088.02
BMS V1039.01
After about 2 hours in UPS mode, with connected fridge, the station turned off. The fridge was using about 80 Wt, before power off consumption was 0 Wt.
ECO and Auto sleep are turned off.
Hi @BLUETTI_CARE ,
I have the same issue. AC180P randomly powers off with 70-110W output. Didn’t see any error codes. It happens 2-3 times in a day.
Bought the station a few days ago.
And also, is it ok if the station discharges in UPS mode? Using it with a computer(around 100W) and I see it discharges to 99% then charges to 100%. The Battery Status = Discharge instead of Standby when it’s 100% in Bluetti mobile Application.
AC180P
SN: 2341000808144
ARM ver: 2089.02
DSP ver: 2088.02
BMS: 1039.01
Please send the new firmware to me too, because… I also encountered the problem of turning off the station under a load of 200 W
S/N: AC180P2349000575473
ARM v2089.02
Hello, i have same problem with UPS, the station turns off after a power outage.
Can i have latest softwear update?
AC180P2349001446229
ARM: v2089.02
DSP: v2088.02
BMS: v1039.01
Above request will be processed ASAP.
@BLUETTI_CARE,
Updated DSP to V2088.04, will test, thank you for the quick response!
UPD: about 3 hours passed since the soft update, no shotdowns are detected.
Hey, i have same problem with UPS, the station turns off after a power outage.
AC180P2349000491882
ARM: v2089.02
DSP: v2088.02
BMS: v1039.01
Hi, @BLUETTI_CARE,
I once again remind you of my humble request to send me the newest available firmware (2088,04) as the above-described deficiency keeps coming…
Many thanks
Hello, @BLUETTI_CARE
I have same problem with UPS, the station turns off after a power outage.
Can I have the latest software update?
AC180P2349001193852
ARM: v2089.02
DSP: v2088.02
BMS: v1039.01
You should have received the new firmware, please check again.
@loki7118 The firmware will be pushed in 24 hours.
Hi @BLUETTI_CARE , my Bluetti has the same UPS problem
AC180P2332001448762
ARM: v2089.02
DSP: v2088.02
BMS: v1039.01
@BLUETTI_CARE Sorry for duplicate, but i don’t know if you received notification about update if i mention you when redacted, so i try again
@Wal.po Received. The firmware will be pushed in 24 hours.
Hi! My Bluetti AC180P is a great device, but I have the same problem with random shutdowns when battery fully charged (ECO not engaged). Can i have this magical firmware to fix that please?
SN: AC180P2349000758862
ARM: 2089.02
DSP: 2088.02
BMS: 1039.01
Good day. I have same issue, please push me a new firmware
AC180P2335001488587
Arm v2089.02
Dsp v2088.02
Bms v1039.01
Brand new AC180P out of the box and the same issue. Please kindly provide the firmware update.
AC180P2335001652063
ARM v2089.02
