Below shows the power, Watts, drawn by 2 AC devices / appliances connected to an AC200MAX AC outlet thru a Kill-A-Watt meter, each connected individually without the other connected at the same time
. According to the Kill-A-Watt meter, One uses very low power, 4.8 Watts, and the other uses much high power, 1167 Watts
. In each case, the AC200MAX screen display shows ~ 44 Watts higher power than the devices / appliances seem to be using as per the Kill-A-Watt meter
So the big question for Bluetti Technical, is the power, Watts, displayed on the AC200MAX AC screen (and the app) the power that is being drawn from the AC200MAX AC batteries ![]()
, or …
