Can I parallel connect two Ac50S 12 volt DC outputs to run my ICECO fridge?
Fridge must sometimes draw more than 10 amps on startup because the circuit faults over current occasionally when connected to just one AC50S.
Fridge works fine connected to AC output. I was just hoping to go DC and keep the inverters turned off.
I read in the manual that you can’t use two power stations in parallel. I’m guessing that may be specific to the AC inverter circuit.
What about the 12 volt DC output?
