Can I go over wattage on solar panels on the AC500? I have access to six 525 watt panels at 45 watts and 10 amps each. With 1 string of 3 panels into each pv input I get wattage at 1575 and voltage is at 135.
Over wattage is fine, just make sure you don’t go over voltage.
It only takes the power it needs, and as long as the Voltage stays below 150, you’re okay.
@skypossum Yes. As long as the open circuit voltage does not exceed the AC500 maximum.
Please refer to the responses from the two members above.
