Unlock the Full Potential of Your Power Station with the B300K!
Discover the versatility of the B300K battery module—designed to seamlessly connect with the AC200MAX, AC200L, AC300, and AC500, offering you the flexibility to mix and match different battery packs to suit your energy needs.
I understand that the P090A cable is the original expansion cable supplied with the B230 B300… It’s the same large connector (with a blue button and a blue switch for locking) at both ends of the cable.
The P90D, on the other hand, has the same large connector (with a blue button and a blue switch for locking) only at one end of the cable (which can be plugged into the B230, B300), while the other end has a different connector.
For example, the different type of P090D cables
(External Battery Connection Cable For BLUETTI EB150 | EB240 | AC180)
