Hi, can I use an AC500 with 4B300? Can the AC500 deliver 5000W with 4B300? Is it possible to expand the system (AC500 & 4B300 & 2B300S)?
Yes, you can use x4 B300 batteries with a AC500 system. However when you use a B300 in your setup, your restricted to 4 batteries per AC500. Additionally your limited to 4000 watts output.
You’ll need an adapter cable to hookup a B300 to a AC500.
@Jo1966 Four B300s can be connected to one AC500 (as long as the B300 is used to access, the battery pack allows up to 4 connections)
So AC500 & 4 B300 & 2 B300S are not available.
