Maxout the balcony system V2. Ideas?
Hey everyone,
i would like to have a system like EP2000, but my roof nearly show completly to north and its really not worth it to install the system like this. The good thing is, i have a few Panels heading to the south, a bit away from my house.
I want to try to maxout my balcony system that take advantage from the south side solar panels and kinda need your ideas for the best way. Here is the setup:
A80P (Inverter):
2x MPPT each up to 60V (800W?)
D100P (DC to DC):
2x MPPT 60V up to 1000W
B300 (1):
MPPT 60V max 200W
“AC” fix 58.8V max 500W
B300 (2):
MPPT 60V max 200W
Right now, two panels are connected to the D100P and the D100P connects to the MPPT inputs of the A80P.
My ideas:
1.) I could connect a Solarpanel on each of the B300 MPPT, but thats limitited to 200W. My panels have more than 500W, kinda would be a waste.
2.) Connect a unit like AC300 or AC500 the B300 while connected to D100P. For this case, i would have another two 150V MPPTs. Not sure if this would work from the software side.
3.) Step down Module for the D100P to bring the voltage down for connection 4 instead of two panels, cant find a suitable step down module for it.
4.) Charge B300s from external Powerstation using T500. Downside here is DC-AC-DC convertation and i always need to manually interact to turn on/off the other powerstation.
Do any of you guys have different ideas or something i could change with mine?
Thanks in advanced
