I have two AC200’s that I would like to connect my 6x120W solar panels to. Is it possible to charge them both at the same time? Maybe with a dual battery solar charge controller?
well the ac200 have charge controllers built in ,are you runnin 3 to 1 each?or you splitting 6 with 2 y connectors.And i dont know if that would work.
I want to run one pair of leads from wherever I have the 6x panels set up outside to the two AC200’s indoors. The panels are wired in series. I’m assuming I can just parallel the generators solar inputs?
