Is it possible to charge the AC50S to 100% from a 12v cigarette lighter output in the car? When I read the specifications it says 16 hours to charge the device under the specifications , but then it says it can only charge the device to 40-50% from 12v output from one of the images on the product page. Appreciate the help
buongiorno, dipende dalla potenza dell’alternatore, ad esempio il mio alternatore manda circa 110 watt alla batteria con una carica da 0 a 100% in circa 5 ore.
For your reference, 98W 12V car charger port can fully charge AC50S in about 6 hours. Time required: 500wh (capacity of AC50S)/98w=5.1h, plus other losses is about 0.5-1 hours.
