Introducing SolarX 4K - The Accessory for Apex 300
@hnymann
The Apex300 has a “system switch recovery” feature, which automatically restores previous settings. In your case, when the energy storage is depleted at night and recharges in the morning, this “system switch recovery” will allow the machine to restore its previous settings, such as turning on the AC output, after receiving PV charging.
The SolarX 4K can be purchased separately. If you want to buy it separately, please contact crowdfunding@bluetti.com for more information. :)
So where can I get a Solar x 4k Charging box?
@Yazz Please contact crowdfunding@bluetti.com for the separate purchase. :handshake:
Question about the DC Output Cable (1.8 m/6 ft, with XT60-F connectors).
Some systems with dual solar inputs do not like the 0 volt to be tied together. For example if you fed both from a single battery there could be issues with reverse current flow. The SolarX 4k is not a battery but it is a voltage regulator and the 0 V would be tied together on the 3 XT60 outputs.
When using the triple XT60-F connector does that mean it is not possible/advisable to connect two of them to the same Apex? Is it designed for each output to go to a different power station or is it okay to connect two outputs to a single Apex, one to each solar input?
@Sideeffect Confirmed: When using a parallel charging cable, the three XT60 terminals can only be plugged into one AP300 separately, and two XT60 terminals cannot be plugged into one APEX300.
what is the max current the Solarx can take? can it have 2 2000W strings in parallel? when will it be available for purchase?
Hello, the maximum current supported by the solar4k X is 80A. Whether you can connect two 2kW batteries depends mainly on whether your energy storage system supports it. Currently, the solar 4k X can be purchased on the official website.
Can you provide a link to the solarx 4K purchase. It does not show on the official website?
OK, can you tell me which website you can order?
Is the SolarX 4K available in the US yet? I can’t seem to find it.
I don’t understand your comment, where is the solarx 4K on the website?
Thank you for your interest! The Solarx 4K will be available for sale in September. Please stay tuned!
Hi, It’s Seot 4
Winter is quickly approaching.
I need to button up my power to my offgrid cabin and my new Apex300
When can we purchase the Solarx 4k?
Respectfully
Hello, the US, Canada, Japan, and Australia will release it in early September, while the EU and UK will release it in mid-to-late September.
do you have a better date? I feel like early September is kinda over. Looking forward to being able to add some solar panels to my installation. Thanks
Hello @jlaine, the SolarX 4K is currently available in the Bluetti store. You can select either cable type, or select an entire bundle. The basic unit is also $100 off right now.
BLUETTI SolarX 4K | World’s First 4kW Solar Charge Controller
I bought my solar X 4K on the indigo go website they sent me my table for my parallel connection to my Apex 300. I have three of them. My question is on the website. It is pictured or it looks to be in the picture that cable has a communication connector. The other two cables it looks like they’re a R 45 jack that you connect to the can one of the solar X 4K. But the cable I received did not have that jack is this cable built properly or do I need to contact blue Bluetti for a new cable thank you for any help
Hello! With my SolarX 4K I ordered the P090 battery connector cable, and yes it does have that CAN bus connector. However, both mine and the other P150 battery cable allow a connection to only a single Apex 300; whereas the one you have can connect to 2 or 3, and I believe that is the reason there is no communication cable included. I have read something to that affect as well, and have not found where I saw that, but I think it is normal.
Thank you for your response. When I go on BLUETTI website it shows a CAN connector. That is why I was wondering
I don’t know if you see this picture
