Anyone know the maximum input amp rate is on the PV input port for the EP240 and the AC200P?
There is no minimum amp rate but there is a minimum voltage amount of 35 volts DC. Realistically you need at least 6 amps at 35 volts to do any meaningful charging though.
Sorry, the question was for the maximum, not minimum. I have a 200amp battery set at 48 volt I was wondering if would be safe to use in the PV port? thank you!
12 amps max. It is my understanding that the AC 200 cuts off any incoming power above 12 A.
