@Mishra42 The wiring diagrams differ from country to country due to the different voltages. Which country are you in, please?
I’m in the United States.
Hi @BLUETTI ,
I recently got my new AC500 after I am already using two AC200MAX that are working pretty well.
Now, for the AC500, my electrician is asking how to connect the 32A outlet of the AC500 in an appropriate way to my house with using the 1st source, 0, 2nd source switch. Would like to ensure the correct connection of the wiring (floating/bonded…) when it comes out of the AC500 and when the AC charging cable connected or disconnected.
Could you please send my the wiring diagram for the use in Germany?
I’d really appreciate your support.
Thanks a lot and best regards
Chris
@ChrisKu I have communicated with the technical department. Once I receive the wiring document, I will send it to you.
Hi @BLUETTI, could you please send the AC500 wiring diagram for EU model please for 32A outlet? I would really appreciate that as the electrician doesn’t want to mess up with it.
Can you also send to me please?
Justrick, I did what you are trying to do, but had an electrician do it for me. Contact Bluetti tech support with the picture provided by BluettiAdmin and they will send you a shopping list of parts and cables you will need to make your dream a reality. It only took my electrician a few hours to wire it all up,
can i also have this diagream please?
european, version ,…
@sneekpeek Pls kindly check.
How to connect the AC500(EU)+B300S to the EU utility power.pdf (7.8 MB)
