Hi @siriusnitro, please rest assured.
I will send you a private message shortly, and kindly share the relevant information with us so we can make the necessary arrangements.
@BLUETTI_CARE, I need the bluetti_device_licence.csv, but I cannot send you a private message. Thank you for your support!
Hi @mariuslinders, if you can’t find the private messaging feature, please don’t worry. I will reach out to you via private message next—please keep an eye out for it.
@BLUETTI_CARE I have been waiting for a response for 20 days. I need the bluetti_device_licence.csv. Please write to me as I am unable to write to you.
@BLUETTI_CARE I would also appreciate a private message as I try to make my AC200Max communicate with HomeAssistant. Thank you.
AC200MAX doesn’t use encryption because it was a model released before they started adding it. Your Bluetooth connection issue is probably caused by the integration you are using. Many integrations now have issues with newer versions of Home Assistant due to changes in Python and asyncio-mqtt.
I recommend this addon which currently works on latest HAOS.
semitop7/bluetti2mqtt: Home Assistant Add-on for bluetti_mqtt
@BLUETTI_CAREHo bisogno del file bluetti_device_licence.csv, ma non posso inviarti un messaggio privato. Grazie per il tuo supporto!
Hi, @BLUETTI_CARE, I’d like to receive the bluetti_device_license.csv file for my BLUETTI Premium 200 V2 device. I want to connect it to my home automation system via esp32. I can integrate it, but I need the Bluetooth decryption keys to use bluetti-lib for communication. I can provide my serial number in a private message.
Hi @jamb2b121, we would like to help you.
We will contact you via private message next. Please keep an eye out for it.
Hello @BLUETTI_CARE,
I am developing a custom local offline dashboard for my Bluetti Elite 100 V2 on a Linux machine. I am using your official bluetti-bluetooth-lib from GitHub.
I found out that I need the bluetti_device_licence.csv file to successfully decrypt the Bluetooth V2 protocol data.
Could you please generate and send me this license file?
Thank you very much for your help and for supporting the developer community!
Best regards,Ivan
Hi @vinni, we would like to help you.
Please click on my avatar to contact us via private message, and send the SN code of your device and your email address. This will allow us to enable Bluetooth authorization for you and send the license file.
You may also contact our support email directly at: service@bluettipower.com
@BLUETTI_CARE i’m looking to get my authorization file; bluettti_device_licence.csv.
Can you send me a message so i can send you my email address and SN code.
Thanks!
Hi @Python, we would like to help you.
We will send you a private message right away as you requested. Please check your inbox.
Hi @BLUETTI_CARE, I need your assistance with authorization file for my Elite 10.
Can’t PM you, looking forward to your message, thanks )
Hi @0ne0ldy0ne, we would like to help you.
Hi @Python, you are welcome!
We have sent you a private message. Please locate your correct SN and reply to us. We will arrange everything for you as soon as possible.
Has anyone successfully gotten bluett-mqtt to work with an Elite 100V2?
