eb3a pass through question
Hi folks,
1st post,Does anyone know why the eb3a’s will not pass more than 600watts when plugged in to a wall outlet.I realize that it’s only capable of delivering 600 watts max because of it’s inverter rating and can be put in power-lift mode when the inverter is activated,but it doesn’t make any sense why it cannot pass say 800 watts wall current.Has anyone had this issue?
Thank you
Hi @ed123
Why doesnt make it sence?
To my Informations, regardless of the source, the AC Plug on EB3A can only deliever 600W permanent power.
Correct me if im wrong @BLUETTI_CARE
@ed123 Yes. What @Selfmadestrom mentioned is right. The max output of EB3A is 600W no matter what sources.
Although the mains power carries the load directly under UPS mode, the inverter needs to be on standby. So the bypass cannot exceed 600W. Otherwise, if the mains power fails, it will not be able to switch over.
because 600 watts is the maximum load the components and wiring are designed to handle.
