Hello, I am a solar newbie and I recently bought a EB150 for a small cabin along with 2*200w solar panels. However, when I put them in series (or individually as well), the EB150 stays at 0 watt of input. It very briefly goes up, to about 20w for 1 second and then goes back to 0, no charging. It is quite frustrating. Any idea what’s happening? I tried to reset the unit, doesn’t work. Bellow are the details of the panels if it is useful.
Thank you for your help!
|Manufacturer model|Eco Line ES200M36|
|Cells|36 pieces monocrystalline|
|Max. Power (Pm)|200 W *|
|Max. Voltage (Vmp)|18.4 V|
|Max. Current (Imp)|10.86 A|
|Open circuit voltage (Voc)|22.68 V|
|Short circuit current (Isc)|11.3 A|
|Operating temperature|-45 ° C to +85 ° C|
|Maximum System Voltage|1000 V DC|
|Power Tolerance|+ 3%|
|Weight|13,9 kg|
|Dimensions|1480 * 670 * 35 mm|
