E113 Error On AC2P Unit
Hello i also have the same issue. Alarm being on and the app says about grid voltage high E113. Can you pls help me.
SN:
AC2P2605110100006
Firmware:
IoT v9046.04
ARM v2146.04
DSP v2136.01
Hello, the technical team will push you new firmware today
Hello, I have registered and pushed the new firmware to you.
How do I check if my firmware is being pushed?I checked in my Bluetti app there is no update yet.I have Bluetti elite 100 v2 by the way
Unit detects AC (relay click) but shows 0W grid input. AC output works. Firmware updated already.
@BLUETTI Same issue! Help.
Grid Self-adaption is enabled in app.
Charging mode is set to Silent
S/N: AC2P2550111243058
IOT: v9046.04
ARM: v2125.04
DSP: v2136.01
Hello @BLUETTI ! Need help. I have the same error E113. I have already done all the steps in the help article.
S/N: AC2P2552110159614
IOT v9046.04
ARM v2146.04
DSP v2136.01
Dear @BLUETTI ,
Firmware updated and issue has been resolved, thanks for your support.
S/N: PR30V22552112424534
Communication board Sn: IOT2552110218571
IOT: v8024. 12
ARM: v2203.11
DSP: v2202. 11
BMS: v1087. 08
  1. Tried this and the display is 2552 11 2424 534
Please help
Thank you. It’s all fixed now
Hello, I have registered your firmware upgrade. Please wait patiently.
hello bluetti
same problem ac2p error e113
OIT V9046.04
ARM V2146.04
DSP V2136.01
AC2P2605110156526
AC2P ERROR e113
Grid Self-adaption: Enabled
Charging mode : Silent
S/N: AC2P2610110050544
Firnware updated:
IOT v9046.04
ARM v2146.04
DSP v2136.01
Plugged into wall outlet:
246.3V
60.1Hz
VE Display: 2610 11 0050
My post is not approved yet. When will you assist me?
Hi Bluetti,
Need help with my new unit AC2P.
AC2P ERROR e113
Firnware updated:
IOT v9046.04
ARM v2146.04
DSP v2136.01
246.3V
60.1Hz
Hello, thank you for your understanding. We have already registered your firmware upgrade request. Please wait patiently
Hello, Same error on my AC70, please help.
E113 Grid overvoltage.
Charged up until 44% during 239V then stopped at 252V.
S/N - AC702610110251935
IOT - v9046.04
ARM - v2151.05
DSP - v2106.09
  1. Enabled the Grid Self-Adaptation in the app.
  2. Set to silent charging mode.
  3. Up to date firmware.
