Dual AC charge advice needed, please
Just got the AC200P and charging it for the first time. I bought the second ac charger and xt90 cable but want to confirm with someone that I plug the xt90 into the aviation plug? Also, do I need to turn the power off to stop charging before I plug the second as power source in? Thank you!
You plug the XT90 portion of the short AC adapter cable to the XT90 portion of the Aviation input cable. You do not have to be powered down to do this, but I would recommend connecting the XT90 and aviation connectors first and then plug the power brick (s) into the AC power outlet.
Thanks so much, Scott!
