D050S not charging AC200 Max
Hi there. I have a D050S which I intend to use with my AC200 Max. However when I connect it to my solar panels supplying about 350w at 80v it lights the Green LED on the D050S but the AC200 Max does not charge! When the solar panels are connected direct to the PV input it works fine! I have tested the AC input via the supplied AC Charger and that works fine. Please can you advise?
The D050S can only take a 60v max so it wouldn’t accept your 80 volts. Green light means not charging, red charging.
Hi Eric
Thank you for your reply. I did not realise that it is limited to 60V. That’s helpful
Nick
