I just purchased a Bluetti AC200MAX Powerstation and I also ordered three LG 380 Watt NeON 2 Solar Panels. I am wondering what accessories I need to connect those three panels (that I am mounting on the roof of our cabin) to the Bluetti AC200MAX Powerstation?
There will be a distance of 40 feet from the last panel on the roof to the power station that will be stored in our cabin.
Thank you dr_torch!
So just to clarify I can use say a 40 foot MC4 extension cable and plug all three into the AC200MAX. I thought I read somewhere about a 900W max and these three panels wattage would add up to 1140W.
I just want to make sure I don’t overload the AC200MAX.
Any additional feedback most appreciated!!!
I can also confirm the 920W max (I also got an additional almost 500W from using the typical AC input with a D050S and connected additional PV panels. I have overpaneled my system with 1400W on the regular 900W input and 800W on the 500W D050S. No issue as long as you do not exceed the max voltage. Current is not an issue as the unit will limit it to rated input.
